Dash Panel Lenses
Lex_Ordo
Long Island, NY
So I bought some of the different color Dash Panel Lenses, to spruce up my duece.
I used Blue for my High Beams, and Amber for my Air Shift Front Axle engagement. They add a little bit of color to the all green interior.
Red looked cool instead of the Amber, but I already have the green covered Red lenses for the dash panel back guage back lighting, so I wanted another color.
Speddmon
Blind squirrel rehabiltator
Cambridge, Ohio
That is a sweet looking truck, I would like to see some pictures of the entire thing. The interior looks better than new!!!
Speddmon
Cambridge, Ohio
Now, that's what I like to see. A beautiful restoration like that, but you're also not afraid to take it out and play with it...that's what these trucks were meant to do and that one looks great doing it.[thumbzup]
Lex_Ordo
Long Island, NY
So here is the new panel getting ready to go in and make the interior even better! In addition, I will be installing a newer Air Shift Front Axle switch, and adding a Green lens to it. I'll get some pics up upon completion. Almost there, just some loose ends that need time to complete
Lex_Ordo
Long Island, NY
Sure thing. Thanks for the compliments.
I used 383 green from Omni-Coatings made by PPG. The shop that I use mixed in the flatening agent, to dull it up. The nice thing is that it is a smooth finish unlike a 100% CARC, and allows the water to bead a bit and run off. I find that the CARC, will hold the water similar to rifle Parkerizing, which is somewhat coarse and holds oil on gun finishes.
HTH
Lex_Ordo
Long Island, NY
Sorry. I put the part/ contractor info in a different thread.
Here is the contractor info along with the part numbers for each lens.
Tiem Engineering Corp
202 Beaver St.
PO Box 790
Yorkville, IL 60560
Tel. 630-553-7484
Lens, Red - P/N 7358672
Lens, Blue - P/N 7358672-1
Lens, Green - P/N 7358672-2
Lens, Amber - P/N 7358672-3
Lens, Red with 383 OD Cover - P/N 7358621
Lens, Blue with 383 OD Cover - P/N 7358621-1
Hope this helps.
