- 2,960
- 31
- 48
- Tiro, Ohio
On the same thought, I've asked two towing companys to tow my Deuce home, and they both said"NO, unless I remove driveshaft first." their reason was I will starve lubrication to transmission and ruin it(even for just 40 miles.)Desert Rat said:Stretch,
I WAS the same way. Need I recap the return trip from Greenville, KY? A direct result from going too fast and slinging the lube away from the bearings.
If spinning bearings sling off all the lube, everything with bearings should fail.
Stretch44875 said:I thought this thread might head towards the transfer case failure issue, seems to be some concern about it. For long hauls, I am at 55 mph.
Desert, are you taking you case apart for repairs, or replacing it? Was yours a sprang or air shift case? If you are taking it apart, take plenty of pics and post for us, and maybe we can figure out for sure what caused the failure, or at least convince some of us that high speed was the cause. You case did run in low range, did you drain the oil yet and see what was floating about? Was the oil level up?
O, I just bought a 63hp tractor, wanna race?![]()
I work as a journeyman machine repairman, and deal with gearboxs everyday. Most don't run at 2600 rpm, or whatever the transfer runs at when in 5th(overdrive).
