Dead Pilot's M36a2 Build
Dead pilot
135
Fallbrook, CA
And the rest of the brake stuff and weather stripping came in today.
All thanks to Big Mike's motor pool
Sent from my SM-N950U using Tapatalk
Tracer
14,380
Hawthorne, NV.
Dead, it looks like your going in the right direction. Can't wait to see it when your finished.[thumbzup]
Terracoma
15
Albuquerque, NM
I also found more info on the truck it self. It's a 67 kaizer jeep m36a2c and I found something really cool. It looks like some papers from it's last unit back in 87.
And I know the Vic number. With the paper it makes it easier to read through the paint
While it might have been a USMC truck in the past, this M36 was most recently a US Air Force truck, based on the paperwork that you've found! The second load list that you posted shows the vehicle ID, and is corroborated with the very faint "68Kxxxx" on your front bumper. This is typical USAF registration number format, as described in this thread.
In the top left corner of both the load lists, you'll also note the unit listed as: 148CCSQ...this was the 148th Combat Communications Squadron, which was stationed at the Ontario Air National Guard Station from 1984 through 1997. It looks like the 148th is still around, except now doing coolguy stuff at Vandenberg AFB.
Dead pilot
135
Fallbrook, CA
Thanks for info. I kinda figured it was a USAF truck at the end of its service. It's kinda cool to find out the history of theses trucks
Dead pilot
135
Fallbrook, CA
Slowly getting the parts fixed up and painted before they go back on the truck. Had a take out a good dent out of the front of the hood. Then I repainted the same pattern that was already there. Fenders are next up then get to the cab. Figured that would be the easiest way to try and match the pattern
Dead pilot
135
Fallbrook, CA
Made some more headway this week. All the cab parts are cleaned up and ready for paint next week. Got the cab on a stand that I modified a bit to put the fenders on so I can get the pattern on to the cab.
Next week will be paint then putting the cab all back together. Slowly getting there.
Dead pilot
135
Fallbrook, CA
This week the cab has been painted green and mocked up on its stand to prep for the painting the rest of the pattern.
Once paint is done I'm gonna put in the weather stripping, the windows and windshields (just need to get the frame to window seals for all them), and on with the soft top. Then it's on to interior parts of the cab. So in few weeks it will go back on to the truck.
Dead pilot
135
Fallbrook, CA
This weeks progress makes the it looks truck is in the house now. The cab and the soft top is all painted, and I got the windshield glass and weather stripping in. The inside cab is slowly coming together. I just need to find the bench seat covers and cushions and the box seat cushions.
Tracer
14,380
Hawthorne, NV.
Dead your M36 is coming together nicely. Dead, JATONKA has the bench seat covers you need, and covers for the box seats as well. Top quality, priced right, and made in the USA. Check out his website. John is also a Steel Soldiers member.
Dead pilot
135
Fallbrook, CA
Dead your M36 is coming together nicely. Dead, JATONKA has the bench seat covers you need, and covers for the box seats as well. Top quality, priced right, and made in the USA. Check out his website. John is also a Steel Solders member.
Cool thanks. I'll go check that out.
Dead pilot
135
Fallbrook, CA
Since painting weather is currently out I've moved on to the motor. And it seems like my radiator has seen better days. It leaks pretty bad from the back and bottom and the front is pretty bad. Is it worth trying to get repaired or should I go try and a replaced stock or aftermarket
cattlerepairman
3,513
NORTH (Canada)
Do you have a radiator shop in your area that does truck or aircraft rads? If so, it may be well worth having the rad boiled out to reveal any damaged areas and then fix it. They can put in a new core, for instance. These radiators are immensely repairable, compared to contemporary products.
A new one makes sense if your quote approaches $800-900. I would bet that you can get yours repaired and looking almost new for a lot less.
Dead pilot
135
Fallbrook, CA
I'll have to check the ones near by to see who does. I may to check closer to San Diego itself though. But if it is repairable that sounds a lot better then a new one.
Dead pilot
135
Fallbrook, CA
A few weeks off and last night she finally made to my place so I can get more work done. Had a friend tow it to my place. Eventful movement but it's now at my place.
USAFSS-ColdWarrior
Chaplain
6,262
Glad you've gotten her home.
Your pic shows a rather RARE configuration!
Many of us keep our trucks "Topless", but your "Cabless" redefines "fair weather" limits. LOL
Thanks for keeping us posted on your progress. :driver::goodjob::grd:
cattlerepairman
3,513
NORTH (Canada)
You know you are NOT a redneck if a friend towed your truck. It could have involved a garbage can on a couple 2x4 duct taped to the frame to sit on and a really airy ride, out in the open, being deafened by the multi without a stack!
Dead pilot
135
Fallbrook, CA
I won't lie if it ran and stopped I may have tried that. Haha. But I was standing on the box steering to get into place. So close enough.
This truck doesn't have a stack she has side exhaust by the rear wheels.
