Decently-priced source for MEP-003 throttle ball joint
Crawdaddy
Louisiana
Today, I went to exercise my MEP-003 genset, and it wouldn't start. Found that the plastic around the ball joint attached to the injector pump throttle arm snapped. My MEP-016B has also failed to the same failure. (among other failures I have yet to fix) Looking at the 24P, the part number is 150-1358. (NSN 2910-00-829-5701) From what I'm seeing, it's no longer made. It looks like Onan swapped that number to be a metal part, which is cool. Trouble is, it looks like the cheapest I can find it is close to $40 each plus tax and shipping...
Should I just get over the sticker shock and open my wallet, or does anyone know of a less expensive source for those ball joints where I can get it?
fb40dash5
159
MD
Do you know the thread size(s)? (I'd assume both the same, but...)
Taking a guess it's 1/4", Snapper # 7015753 is 1/4-28, and widely available online for cheap. If you wanted one now you could probably walk into most small engine dealers, they're commonly used on zero turn mowers for control linkages & such.
Crawdaddy
Louisiana
Unfortunately, 1/4-28 is too big. I don't want to pull the currently jury-rigged joint off of the MEP-003, but eyeballing it, it looks to be identical to the one my on 016B. (despite having a different part number) Assuming that's true, it appears to be 10-32 threads. I just ordered a couple off of Amazon. Hopefully it fits and works. We'll see on Thursday.
FarmingSmallKubota
1,109
Wapakoneta, Ohio
Technical Characteristics
END ITEM IDENTIFICATION(AGAV) GRUMMAN A-10 ACFTBALL END THREAD DIRECTION(BFZC) RIGHTBALL END THREAD LOCATION(BFYY) EXTERNALBALL END CONNECTION THREAD PROVISION(BFYX) THREADEDBALL END THREAD SIZE AND SERIES/TYPE DESIGNATOR(CZLE) 10-32 UNFLENGTH(ABRY) 1.219 INCHES NOMINALSOCKET END THREAD LOCATION(BFZK) INTERNALSPECIAL FEATURES(FEAT) NONADJUSTABLE;SOCKET END THD SIZE,10-32STYLE DESIGNATOR(STYL) SINGLE, RIGHT ANGLE, PLUGGED
