Decisions on M1008
DooDooBrown
MS
I am considering converting to 12 volt.
I am having ALT problems on my M1008. I bought a new ALT of ebay and installed it on the passenger side. I checked out the drivers side and all is well. I am having a similar experience to this thread: http://www.steelsoldiers.com/cucv/50779-new-alternator-now-doest-start.html. The ALT is from the same ebay seller. I am thinking just to go ahead and do the conversion.
My starter has been swapped out a year ago and is already 12V.
Any advise on the pros and minuses? The end state would be a reliable, simple vehicle that I can get parts at from any local auto place.
4bogginchevys
rathdrum idaho
before you go making big changes in the electrical engineering of the truck you should probably fix it in it's current condition.....I didn't read the link you posted but I cant think of any good reason to convert to 12v because of a simple alt issue.....2cents
Edit: I read the link. Can you switch the alts so that the Iso- alt is on the pass side/non iso-alt on driver side? If not you can aquire another failed alt with iso-stuff from a member here and insert necassary parts. I'm really just saying that when an electrical system has a problem it is the worst time to re-engineer it. Good Luck
DooDooBrown
MS
I can agree with that. The jest of the link is that the supplier on ebay is not isolating the ground. Isolation the ground on the passenger side will fix the current problem.
I read the boards here and have been around these trucks at work and it just seems that there is always problems centering around the charging system. There has to be a better solution in simplifying it.
