unclemikey
- 97
- 0
- south west
Wow, first time being little is good! Your answer......Crew Cab.
Not all pedals have the notches. My '87 did not, I was woundering why the pedals seems so much higher on that truck. After looking under the truck and others I found that it had the pedals higher and did not have the adjustment notches. They do now thought.A thinner back cushion is the trick, especially with a spring seat. That rear cushion just doesn't need to be that thick. Another thing you should be aware of is that the pedals are adjustable. Look underneath, remove the bolt holding the pedal and twist and work it out. You will see the multiple notches (3 IIRC). Adjust from there for best fit. Another member took the whole seatback off and attached it to the back wall of the cab. I think with a little effort you can achieve a fair fit. Last option for belly clearance is a shorter steering shaft but this will effectively lower the steering wheel.
Wiper motors are upside down!did i read that right?? he put his wipers on upside down ??
