lostinutah
- 0
- 6
- pleasant grove, utah
Can you just bolt those jerry can mounts through the body or do you have to weld in supports?You could just modify a set of Jerry can mounts![]()
See how easy that would be? And on the bottom edge I would put a piece of rubber trim so it does not mar the side panel. Easy as you can get. And no damage to the truck at all. Unless you hit something while you have something mounted out there.
