Have you replaced the 20 year old tires the military had on it or the 20 year old o-ring between the rim halfs rubber dry rots over time ?Sorry guys my lack of proper teminology. 2 piece rim. It's not leaking at the tube going into the rim, when I spray it into the hole around the tube I start getting bubbles. The seal between the two piece rim has a very slow leak. Takes two or three days to deflate.
Not talking about older MV system, talking about now. W'ere only talking about 11 years.so does the older MV suspension, the springs and pocket take care of the side to side movement, and the torque rods take care of the roll and front to back movement , you loose a torque rod (strut) on a modern truck, look what your axle does, at times it goes where no axle has gone before.
Are you testing me? Looking for a reason to ban? Been looking at private messages?Unless your parts are new and went bad, how can you call it a flaw?
Are you a suspension design engineer as well as a truck driver?
Tires are good. Sprayed soapy water around all tubes inlets including from the rear side of the rim. When I spray into the hole through the rim I get bubbles.Have you replaced the 20 year old tires the military had on it or the 20 year old o-ring between the rim halfs rubber dry rots over time ?
As for OTR trucks have you driven one with wore out bushings in the walking beams they will travel far enough to rub the tires on the frame and if bad enough cause tire blow-outs.
Are you saying having 4 leaf springs in back? Have you seen the m35 articulation at full deflection? It's pretty impressive in my opinion. Personally, I have never heard of a failure except on older torque rods.Not talking about older MV system, talking about now. W'ere only talking about 11 years.
Normal truck
http://imageserv8.team-logic.com/store-logic/categories/5/778/532.jpg
You have the leaf spring with two contact points, and the middle supported by 4 bolts with possibly some torque bars. With the M35, you have a reversed leaf spring, NO contact points other than the spring pressure and one or two torque bars. The design is inherently less stable and susceptible to catastrophic failure
Okay so they failed to find the A3 rod about to fail with 5,000 miles on it?Are you saying having 4 leaf springs in back? Have you seen the m35 articulation at full deflection? It's pretty impressive in my opinion. Personally, I have never heard of a failure except on older torque rods.
He must have stayed at a Holiday Inn Express last night .How do do know it really has only 5000 miles on it? Suppose that torque rod is original to your 40 year old chassis?
Rubber deteriorates. The design is not flawed.
You didn't answer my questions posted above.
Are you always paranoid?
Suppose I was an engineer? I've built a lot of things, the design is non-redundant. Doesn't take an idiot to see that. One failure leads to catastrophic failure of your brake lines leading to death or injury.How do do know it really has only 5000 miles on it? Suppose that torque rod is original to your 40 year old chassis?
Well I don't think the tires are 20 years old considering the truck was rebuilt in 1998. I wish, cause then I wouldn't have to pay half the registration cost.Have you replaced the 20 year old tires the military had on it or the 20 year old o-ring between the rim halfs rubber dry rots over time ?
It's all most the same as a Mack camel back suspension and it is not a poor design.Okay so they failed to find the A3 rod about to fail with 5,000 miles on it?
Still doesn't address my point. You have ONE point of contact with the leaf spring leaving all kinds of failure prone issues.
Don't other than the odometer and the minty condition of the truck. I would find that odd on an A3.How do do know it really has only 5000 miles on it? Suppose that torque rod is original to your 40 year old chassis?
This broke in my yard driving over gopher mounds in the back yard. Seriously? Special built military trucks to the lowest bidder. The fact that one rod failure will cause you to have brake failure speaks volumes. POOR design. How can you argue that? Put a steel shield over the brake line if the rod comes off or breaks.One thing you may be overlooking. These trucks were never made to federal saftey standards for civilian on road use.
They are special purpose built military trucks.
