Detailed Drawings 931A2
jg210302
Huntington Beach, CA
Does anyone know where there are detailed dimensioned drawings of 931A2 trucks? I have found some drawings of basic 931 dimensions but none of 931A1 or 931A2. The more dimensions the better, specifically I would like frame and 5th wheel height and location with singles, and cab dimensions.
Thanks!
1,168
Are you suggesting the TMs do not list this?
jg210302
Yeah, I looked through every 5 ton TM and could not find the dimensions I am looking for. Maybe I am missing it, but I could not find any detailed drawings. Is there anyone that has any drawing that may help?
jg210302
Here are some of the drawings I have been able to find, no luck here with much detail at all...
I know better than to ask before going through hundreds of pages of TM's, but I am looking for more detail if possible...m931.jpg5 ton dimensions drawing Three of threes_1250402326156546401.jpg
wheelspinner
1,511
North Carolina - FINALLY !
What exactly are you looking for? These are pretty explicit. I will tell you that I measured two trucks side by side at Ft Drum. The 931A0 was 46" at the ramp as indicated in your first example. The 931A2 that I bought was also there and it measured 48" at the same point. So the fifth wheel height would also follow at 2" taller.
jg210302
Wheelspinner, that information actually helps, thanks! What I am looking for is just more detailed drawings... The specific information is measurements such as swing clearance with the larger spare, height (from any reference point) of the windshield when up, distance from back of cab to the swing clearance, etc...
Thanks again for any help guys!
Jeremy
