Details on ringmount plate rivets.
jwaller
19
Columbia, SC
Yeah, I think mine is an A3 cab. I'll post some pics when I get it back from being sandblasted and painted. (it was galvanized, and the paint was flaking off it everywhere).
if it were an A3 you'd also get the 3 point seat belts and would have had an insulated floor and no provision for a clutch pedal. very cool anyhow.
FWIW there is an additional small cab plate that mounts to the rear mating surface where the original hard top would go. it's more or less a piece of angle iron that goes from side to side. it's also nice to have if you are going soft top. adds a little more stiffness to the cab.
jesusgatos
on the road - in CA right now
Of course you're right. I guess what I've got is a late-model A2 cab. The slave-cable hole in the cab is blocked-off, and there are no holes for the soft-top tiedowns, but no insulated floor (dangit) and no shoulder harness mounts.
I'd like to see pictures of that other cab reinforcement that you mentioned.
glcaines
2,756
Hiawassee, Georgia
I just bought a brand new cab, NOS, still in the crate (er, what was left of the crate). Anyway, it's got that reinforcing plate in it. Lemme know if you guys need any measurements or pics before I install it.
I like a picture of the installed plate, distance between rivets, etc. if you have time. Thanks.
JCKnife
46
Kentucky
From another thread, I understand that the rivets needed for installing the cab reinforcement plate are:
55-1/4" Blind rivets NAS1398C8-5 Grip Range(Thickness of Materials) .251-.312"
40-1/4" Blind Rivets NAS1398C8-3 Grip range(thickness of materials) .126-.187"
Are these the correct rivets, and if so does anyone know where these can be purchased in these quantities? I've found so far that no one is interested in selling anything less than very large quantities. I'm ready to install my reinforcement plate.
I've also been searching for the correct spec on the reinforcement plate rivets, and this is the best post I've found but seems unverified. Also I'm not sure if the above is spec'ing 2 different rivets in different quantities?
joshuaz223
Central Square, N.Y.
thanks for the info. everything except the firing rate sounded 50 cal right down to the brass and links. spent a lot of time behind the M2 never heard of the 50 cal M3. thought the M3 was a grease gun.
wsucougarx
Washington State
not to be argumentative but i dont believe that was a 50. Ma Deuce speaks with much more authority and with a slower John Wayne gate.
Sorry but I'm going to be argumentative:razz: It is a .50 cal. It is not your typical M2 .50, but a M3 .50. If you look at the suppressor that's a dead give away. Here's another video of the M3.
[media]http://www.youtube.com/watch?v=vCUhVDjBaI8[/media]
jesusgatos
Would like to know more about that insulated floor?
My cab had a small plate welded on top of the rear part of the cab on the pass side, and when I cut it off to make for a more uniform hardtop mounting surface, noticed that there was a mfg number on the bottom of it. Guessing that it was part of the cab reinforcement kit? Anyway, just thought some of you guys might like to see it. Would be very easy to duplicate.
