Detroit Locker chipped tooth on splined coupler. Still good to buy?
Superthermal
1,039
Utah, Murray, United States
Looking to purchase a used Detroit 5Ton locker out of a 900 series for my M813. The locker has a single half broken tooth. Still good to buy? I dont see any other damage to the adjacent teeth. From the exploded view it appears the collar shares the load with all the teeth simotaniously and one missing tooth may not be that big of a deal. From the last pic below either the machineing was poor or the tooth was improperly machined. or is this gear actually broken and pressed outward?
Welder1
164
Albany Ga
View attachment 880725View attachment 880726View attachment 880727View attachment 880728
I would pass on that. Its too much work to install for marginal parts.
Superthermal
1,039
Swapped in two new Detroit lockers into the rears and am doing the third this week on the front. I am with you, that was a lot of work to put in something that may let go. Who knows maybe it would have been OK.
Either way, I did pass.
In researching this issue though, I talked with the very knowledgeable owner of Gearheart Engineering who makes custom shafts etc.. for the 5 tons. His explanation was that when you brake an axle shaft and the rebound happens with the 1/16 or so rotation slop of the locker the shock of that unloading of tension is what chips and breaks the teeth on the Detroit.
