res0wc18
- 2
- 18
- Everett, Wa
anyone hear put a detroit up front in their blazer? Or had one put in?
True, a set of 1008 axles would do the trick nicely.DMgunn said:unless it is a dedicated crawler, in which case you've got the wrong axles anyway.
Good point. Forgot to mention that.I haven't had good luck with the Lock-Right, although they do stand behind there warranty. The need to fit inside the carrier obviously limits the area of engagement for the teeth, and I've personally stripped probably three of them completely.
No ball joints to worry about, and kingping rebuild kits are cheap.steelsoldiers said:Yeah, but it'll be slap wore out and need $500 worth of ball-joints, u-joints, carrier bearing, brake rotors, calipers, etc... I shopped for a D60 for a while when I had my M1009 and there were some real turds out there.
Only the newer 97+ iirc ford axles have the ball joints.steelsoldiers said:Ball-joints in the Ford HP D60. I drive a Furd so I had ball-joints on the brain.
I'm sure there are a few decent D60's to be had out there for less than a grand, but when I used to hang out on CK5 all the time there were countless stories of guys getting that mythical "cheap" D60 in a barn and then having to pump $4-500 in parts into it.
Gov-lock(G/L) Used by General Motors in 73 & newer trucks that came with an option locking / limited slip differential. It was used in 7.5", 7.625", 8.5", 8.6", 8.875" 12 bolt truck, 9.5", 10.5", and now in the new 11.5" differentials. The smaller designs are fairly weak and the 8.5" and 12 bolt truck designs are especially weak. The 9.5" and 10.5" 14T units are fairly strong and will hold up well to towing and moderate abuse. The Gov-Lock is designed to act as an open differential during normal driving with no force being applied to clutches. This fact that no force is applied to the clutches keeps the clutches from chattering during normal every day driving. When either wheel slips and spins approximately 100 rpm faster than the other a governor assembly senses the difference in speed and activates a ramp system. The ramp system causes the clutches to engage and transfer power to the wheel with traction. One other feature of the Gov-Lock is that it will not engage at vehicle speed above 30 mph. This no lock-up feature keeps the vehicle more stable at higher speeds where both wheels spinning could cause an inexperienced driver to spin out or slide off of the road. This is a great design in theory and works as designed in a stock vehicle that is not abused. The problem is that most of us modify our trucks and many of us abuse them. When this unit is asked to deliver under extreme conditions it tends to self-destruct. The force generated by the ramp system that is used to lock-up the clutches works well, except that same force has to be contained by the case and the case is not always up to the job.
So true. My 1009 gov-lock committed suicide whilst I was pulling donuts in a muddy field. It still worked OK in a straight line, but going around corners it went pop, pop, pop The little weight from the gov-lock and pieces of spider gears were found in the bottom of the diff. It was ugly, but it failed because I abused the pee out of it.DMgunn said:By the time it locks, the spinning wheel is at 14,000,000,000 rpm (since so many people are unable to resist full-throttle in a spinning situation), and the engagement is very violent at that point.
