Csm Davis
- 393
- 83
- Hattiesburg, Mississippi
A lot of the 1008 had gov - lock in the rear and many were changed to the Detroit in service. All of the 1028 had Detroits.
The parts TM's show only the Detroit in all UOCs except 209 which is the M1009.A lot of the 1008 had gov - lock in the rear and many were changed to the Detroit in service. All of the 1028 had Detroits.
I should be in town tomorrow so I guess I'll get the stuff and check it out but it might be next week before I get time to yank the cover. But i should have time to try jacking up the back and try the tire turning thing.
This here is my truck I thought yall might like some pics
Leave one tire on the ground, transfer case in neutral. Spin the tire off the ground by hand fast enough at it should lock. Mine did.... Realistically, the Gov-Lok will feel like an open diff when you jack the rearend for inspection...
It is the only way to know for sure and it doesn't take any longer than reading through 3 pages of guesses in this thread .Its tough to figure out what "acts like a limited slip" really describes. Is it both tires spinning exactly the same speed or both spin but one more aggresively. I don't believe the 14 bolt ever had a gear driven or clutch type limited slip. Only a Detroit or Gov-Lok as far as I'm aware. Both will spin both equally when locked up. The Gov-Lok typically lets out a loud bang when disengaging.
Just pull the cover to see what you have. Nothing short of that is guessing. Realistically, the Gov-Lok will feel like an open diff when you jack the rearend for inspection. The Detroit just feels like something is broken which is normal.
Thanks for the info. I'll try to do that this weekendLeave one tire on the ground, transfer case in neutral. Spin the tire off the ground by hand fast enough at it should lock. Mine did.
