deuce airpack/master cylinder rebuild
frank8003
4,990
Ft. Lauderdale, Florida
I state that if you want the brakes to last, all parts of them, then they must be exercised.
That is easy to do by supplying air backwards thru a glad hand and operate the brakes repeatedly for a couple of whiles once in a while. Can't hurt. The fluid sits in the bottom of the wheel cylinders, WC up moisture to the fail point. Use or loose.
cylinder 4.jpgcylinder 2.jpgcylinder 5.jpgcylinder 6.jpgcylinder 7.jpgcylinder 9.jpgcylinder 10.jpgcylinder new 11.jpg
Tracer
14,381
Hawthorne, NV.
View attachment 487088View attachment 487089
There are two types I use. One is the recommended grease of "Bendix". It is made by "Dow Corning" and called 'MolyKote 111' . The second one, and the one I prefer is "Super Lube Synthetic Grease". I apply a thin layer to ALL exposed metal surfaces.
Rusty, have you ever heard of or used Molykote G? A friend of mine introduced me to it decades ago, and it works great. They advertised Molykote G as having microscopic ball bearings.
rustystud
3,389
Woodinville, Washington
Yes. I've used it for years. Great stuff! In fact I believe I mentioned using it on the "air" side of my air-pack rebuild. (At least I think I remember the new number was "111" . They stopped using the number "G" I believe) . It's one of only a few greases that will hold up and not cause any damage in a air system. Manufactures like "Bendix" uses it in their air system components.
Tracer
14,381
Hawthorne, NV.
Thanks Rusty. I didn't know they had changed from "G" to "111". That's why I haven't been able to find it I thought it was out of production. I'll have our local NAPA store order some.
