Stalwart
- 33
- 48
- Redmond, WA
Can electric drum brakes lock the tires of a loaded trailer, I really don't think so.
Havent had to use it yet. I tested it @ 20 mph in a walmart parking lot and stoped the truck and trailer combo pretty quickly. Granted it was flat ground an in a controlled environment. I would wager that hitting that switch, and pulling the fuel cut off switch to turn the engine off would bring the truck to relativly quick stop with all things considered.Whoa Josh, that sounds like an all-or nothing approach. A braked, but not locked up, tire has better traction and stopping power than a locked up tire. Not to mention the flat spots you're getting on your tires every time you flip that switch. Plus you have to remember to flip that switch when you need it most.
If I find I will be towing something this heavy, I'll look into a trailer brake controller.
yes my 8k car trailer loaded up with a M1008 and a set of 11:00 NDCC tires the brakes sure can lock up. IF there adjusted correctly and in good working order.Can electric drum brakes lock the tires of a loaded trailer, I really don't think so.
I carry a lot of tools, spare chains, parts and spare tires in the truck as is evidenced by the ~17,000 lb truck weight. Some of that is tongue weight but 2-3 tires, a 5 ton tool box full of tools, and other bits on an M35 winch truck adds up.Continuing phase two of the trip to PA, I drove from where the truck was stored with the Dingo and Trailer in Hatfield PA to Reading, PA for the Airshow and then from there a 4 days later back to Atlanta.
Total miles for both up to PA and back to Atlanta was
1346 miles
Total Fuel for both to and back from PA was 208 gallons not including the last 76 miles from the Wilco Hess Truck Stop in Carnesville GA. Based on going up and down hills along various legs, I got ranges of fuel economy from 9.2 mpg on the leg from Fort Chiswell to Carnsevile to 7.2 from Georgia to Fort Chiswell. Most of the ratings were 7.5-7.8 coming back from PA.
Overall average speed was around 48 mph, 53 mph was comfortable. The GPS indicated that the truck would go to 57 mph at red line, whether this was error on the speedo or tach is unclear, but I tried to stay at 54mph or lower based on GPS indicated speed.
In Pennsylvania, I added lockout hubs to the front wheels. I didn't notice any clear change in feel, but I hadn't driven the truck in months before I put the lockout hubs on.
In Carnesville, Ga, I stopped and weighed at the Cat Scales to see what total weight with fuel was.
Weight for the truck was:
6460 lbs on the steer axle
10720 lbs on the drive tandems
9020 lbs on the trailer's tandem axles
Gross weight was 26200 lbs
I ran 75 psi on the front tires, 60 psi on the rears and 90psi on the trailer wheels.
Modifications to the truck to date are:
-Overson Engineering Lockout hubs on the front axle
-dual front floods under the bumper
-single rear flood aimed at the trailer
-24-12 volt converter added to the firewall for power to an accessory jack under the dash for the GPS unit and iPod for music as well as power for the Tekonsha Brake controller mounted under the dash at left of the steering wheel for trailer electric brake controls.
I considered such an adaptation and reconsidered the "Inertia" electric controller I installed in a smaller pickup.I'm working on a design of a "air over electric" controller for the deuce. It will consist of a air cylinder and a rheostat that will control voltage to the amount of pedal. I'm having trouble getting the air pressure and output voltage adjusted right but I'll get it worked out.
I didn't know they made such a thing. Looks like that would be the easiest route to go.Instead of the rube-goldberg setup, why not just get a 24v to 12v trailer brake controller? They are out there, you just have to pay a little extra shipping...they are fairly common in Australia, for example, where both 24v and 12v vehicles are common.
Jim
