Deuce Brake Drum
DHennon
Orlando, Fl
In the process of wheel bearing repack, seal replacement, and wheel cylinder replacement on all wheels. I have all the TMs at hand. Does anyone know how much a front and rear brake drum on a deuce weigh? :idea:
rlwm211
Guilford, NY
They are all the same. The hub assembly weighs near 100 pounds and can be a finger pincher when you put it back together.
Make sure you have the 8 sided 3" socket for loosening and tightening the bearings.
Tow4
620
Orlando, FL
I think the rear hub/drum assembly is about 80 lbs more or less. I can get them off and on by myself and I'm not a big guy. I did use a hand cart to move them around though.
Karl kostman
836
Fargo ND
I would agree the hub/drum assembly is at least 100 pounds and as far as the 8 sided socket for the hub bearing nut be careful on my first deuce they were 6 sided!
KK
