LOKI85
- 0
- 0
- New Albany,ms
I have a issue with my truck it's a M35A2. I have turn lights running lights but no break lights.
You know where it is correct?
The manual.
If not, we'll get the Steel Soldiers Troubleshooting Department all over it. Best of luck!I'll air it up and see if they come on tonight, I bet they do...................
Needs air Pressure to operate new style air switch!! Just short between the two wires at the switch no matter witch type you have and they should light . Also the 3 lever switch must be have power to lights on . Test with a test light to see if you have power at the brake light switch , if so short between the 2 terminals and it should light the brake lights . If it does not remove the tail light lens and check for current at the bulb contacts while the brake switch remains shorted, if you have current there then you need new bulbs !! Good luck and have a great and safe day, Dave
