Deuce brake line repair
uriss
French Settlement,La.
Trying to search the TM for help and or diagram for the front driver wheel brake line. Trying to replace the hose but in true military fashion the previous mechanic bitched the heck out of the brake line fitting. I broke one side loose and got the mounting bracket off but in a quandary as to remove the line at the next fitting. Don't really want to try vise grips as there isn't much room to get in there. Any suggestions for a man with a bad back trying to wrestle a Deuce into submission?
What I am trying to find out is how the steel line is routed going into the wheel? If I break it is it a major hassle to repair?
Scar59
41
Mt. Eden, KY
Brake line attaches directly to the brake cylinder w/ a banjo fitting. To change the cylinder, the wheel and hub/drum assembly comes off. Not a job for a bad back.
Kaiser67M715
26
NH
are your trying to replace the hose that goes to the wheel? or the steel line that runs from the "t" by the front driveshaft to the hose that connects to the front wheel?
the hose attaches to the wheel cylinder by a banjo bolt, then to the bracket, and finally the steel line threads into the hose. it sounds like you have the bracket off, so you probably already did this. on the banjo bolt you can use a six sided socket and ratchet.
as for the "t", a pair of vise grips can be used to prevent the "t" from turning as you use an actual flare wrench on the line(a good one, the cheapos from autozone will NOT work on stubborn flare nut)
I believe a 5/8" wrench will fit snugly over the "t" as well to prevent it from turning(prying on the "t" will cause the bracket to bend and in some cases break it off.
gringeltaube
Staff Member
2,300
Montevideo/Uruguay
.......................... What I am trying to find out is how the steel line is routed going into the wheel? If I break it is it a major hassle to repair?
Sounds like you still have the early style brake line? If so you should try to find the parts to convert to the later style upgrade.
The early style brake hoses are very short and subject to relatively high flexing.
Below are extracts of the TMs trying to explain the difference...
G.
