Deuce changes for Haspin 2010
dittle
72
Albia, IA
Just got done installing my turbo (boost) gauge and the civy wiper conversion with the Anco blades/arms. Next I am going to bypass the FDC, re-set the fuel (hence the turbo gauge need) and install a 24V to 12V power converter. Need to get a CX-13908 cable to run from my MX-7777 surge suppressor to the converter but I might know of one.. If not, anyone have one they would be willing to part with?
1,124
I like the instrument cluster mod, very clean.
dittle
72
Albia, IA
Thanks guys, the instrument panel mod was pretty easy to do. The original high beam hole is centered perfectly with both the bottom row of gauges and with the oil pressure gauge. So all we did was made a jig that bolted into the original high beam bolt holes, marked the center of the big hole where the light used to come through and then used a 2" hole saw to go through with. Had to hit the edges just a little bit with a die grinder as I need a 2-1/16" hole for the gauge.
For the new high beam hole we just marked center b/t the dash lights and then center between the speedo/tach and the bottom row of gauges. Used a uni-bit to get the through hole for the light, marked the mounting holes and was pretty much done minus painting.
dittle
72
Albia, IA
It was the only one that NAPA had that didn't require electricity and was close to the original gauges. Vacuum might be used if the engine ever starts running backwards, but I hope it doesn't.
Keith_J
1,315
Schertz TX
Vacuum is a great sign of filter clogging.
I would recommend a pyrometer (high temperature gauge) pre-turbo if you are going to turn the fuel up.
dittle
72
Albia, IA
Actually going to be turning it down after I bypass the FDC. Was flip-flopping between turbo and EGTs. I decided the turbo would be easier to install and re-set the fuel with, especially in single digit weather.
