deuce charging
Barneyszoo
12
Riverside, CA>
I have a battery charging question. I drive my bobber every day as a daily driver to work and to the store exc. The batteries never seem to get fully charged with the short trips, do you think that turning up the regulator would help charge the batteries to full.
o1951
155
Bergen County, NJ
If you turn it up too much, then when you run it longer, you will boil the electrolyte. That considerably shortens life of batteries, and sprays fine acid mist in vicinity. If they are working properly, the generators have sufficient capacity to quickly charge batteries.
Charging voltage is 13.8 for new batteries, 14.2 for older ones. I would not turn up above 14.2. I would run a capacity test on generators.
WILDBOY6X6
Newark ca
HI yes this is right,do a load test on genarater check volts then turn on everything,lights 4 way flashers wipers etc see if it still will put out full charge.
Thats a gen not alt,the way to tell is if it puts out full charge at idle its a gen if only full charge at higher rpm's its an altternater.:beer:
Bobbyconti
Sanderson, FL
I know this is an older post, but I would like to add something. If your still running the old prestolite alt, they are antiques, and hard to work with. I converted mine to a 24v delco setup (a new alt. runs 240 bucks, they are easy to rebuild, and very reliable. You just have to make a new mount. It's not difficult . Also, remove your positive cable from your alternator and start your truck. If your alt. has 0v at the positive stud, it's an alternator. If it has 24v with the cable removed, it's a generator. A gen. Will produce its own power. Hope any of this helps.
