Deuce compressor in my M715 ... need help
Kamikaze12volts
QC Canada
Sorry to bother with that but had found nothing helpfull. Someone gave me a complete compressor from a Deuce but i need to know some details about it ..
I know that i will need an air governor to control it .... ( need to find it )
I have the IN and OUT ( which i am sure !!! )
I have two other fittings ... one from the head with copper line installed in the fitting ... the line is about 1/4" in diameter .... but where does it go ?? And i have another fitting from the back that goes ???
Also does the compressor need to be installed flat ?? Or can i clock it like the York unit ??
The unit is a MIDLAND MS-51322-1
I will take pictures this afternoon and post it to help figure it out !!
Thanks a lot !!!
gimpyrobb
dumpsterlandingfromorbit!
27,791
787
Cincy Ohio
The fitting that goes in opposite of the pulley is the oil feed line. The oil falls into the crankcase out the bottom of it, so I would hesitate to mount it sideways. The other fitting, 1/4" line that goes to the head, is what goes to the govenor and controlls the unloader valve. I have an extra air govenor if you can't find one. $15 plus the ride.
Kamikaze12volts
QC Canada
OK thank for the fast respond !! But with the oil inlet .... if filled with oil and plugged ... it should work ?? I will look local for that governor ... if cannot find something a will let you know !!!
