Deuce doesn't like going backwards
hughscpa
Coffeen, IL
I have an issue with the bobbed deuce. It runs forward great and shifts fine. No grinding going into any gear including reverse. But this thing does not want to go backwards. It started acting up as if the parking break would stick and it would not go backwards. I would put it in first bump it forward, back in reverse and all was fine. It sat most of the winter and when I hopped in it yesterday, it did not want to go backwards even after "breaking it loose" by going forwards. The engine bogs down like I am pulling a load and can't get it rolling. The times that I did get it to go backwards, when I push in on the clutch it actually would spin both back wheels forward and start me rolling forward. I tried pulling it backwards today and it did not want to go even in neutral. Any suggestions? Thanks.
Scar59
42
Mt. Eden, KY
Your truck is mostly equipped with a sprag engagement transfer case. Correct? No air shift? If this is the case, something in the sprag/transfer case is afoul.
OD_Coyote
58
North Bend, WA
You may want to jack each wheel off the ground to see if any of your brake shoes are stuck to the drum.
Based on the fact your rear wheels spin when trying to backup would indicate the issue may be with the front brakes.
pctrans
19
Bradenton, FL
Or more likely, one of the springs/bracket on the parking brake shoe assembly is bound up. One of mine did the same thing, except in forward. Soak the area in PB Blaster.
hughscpa
Coffeen, IL
This old girl has the air shift transfer case. And when I say "spin " I mean it is as if they are under pressure and spin as if I was doing a burnout. Now that would be something to see. I would explain it as if it was one of the old rubber band powered airplanes I had as a kid (great toy by the way). Going in reverse I am winding up the propeller.
M543A2
15
Warsaw, Indiana
If you find it is not the park brake, and it is not an air shift transfer case, then there is a link rod from the transmission cover to the transfer case that is to shift the transfer sprag for forward and reverse. Check it to be sure it is properly hooked up and moving as you move the shift lever from forward to reverse.
Regards Martin
Radiogeek99
Just Another Guy
55
Homer Glen, IL
I had a similar problem, a few of the cages on the bearings in the transfer case broke off and got caught in the gears. I hope that is not your problem.
hughscpa
Coffeen, IL
Well I backed it up and like before it got to a point and it broke though the pressure point and then backed up fine. Stopped it and then tried to back up again and it was back to not wanting to back up again. It rolls forward fine. If I disconnect the back driveshaft I should be able to see if that continues to lock up without the drivetrain pressure.
Scar59
42
Mt. Eden, KY
Try taking the front axle caps off the axle, this will take the front axle/transfer case out of the equation. Then back up and see if the binding continues.
VPed
315
Clint, TX
You should only need to take one off cap unless it has a locker in the front (unlikely).
gimpyrobb
dumpsterlandingfromorbit!
27,791
791
Cincy Ohio
Crawl under the truck and make sure your parking brake springs (yes both of them)are not broke. What you describe is parking brake out of adjustment.
hughscpa
Coffeen, IL
You guys can't be thanked enough. It was the parking brake. Too much grease had been used and it had gotten on the inside of the drum and collected road grime. Go in reverse and after a short spin, it would lock down on the drum. Cleaned it up and all is well. Thanks again guys.
cattlerepairman
3,533
NORTH (Canada)
I find it amazing that road grime, caked with grease, is able to lock up a drivetrain with a low gear ratio reverse gear, powered by a 140hp engine. I'd have thought the chunks of caked whatever would be sheared right off the drum. Live and learn.
gimpyrobb
27,791
791
Cincy Ohio
Its the design of the pivot. It multiplies with pressure going backwards and let it spin easily going forward.
Way too easy to toast the pads! I've done it many times.
randini
salt lake/utah
I have the same problem. No grinding sound, or feel just will not roll backwards. I looked at the parking brake, and loosened the pads. I never thought about looking for grease. I will report back, after the inspection, I am excited!
