Deuce done!
FreightTrain
Banned
2,730
13
Gadsden,Al
But not in a good way.I called off the gasket replacement.Found 2 holes scored real bad.Haven't even pulled the rear head.Front 2 Cylinders have a spot top to bottom about an inch wide that has a DEEP score running straight down.Guess that is that.How much do bearings,Pistons,And sleeves cost now days?
Manstein
Chaplain Emeritus
331
Cartersville Ga.
there is a couple of listings on GL for groups of six engines. At least one or two in each batch look new. Might be a better solution. Of course six engines makes for a long trip back from Ft Bragg.
poppop
39
Brooklet, Ga
I always like to build my own engines rather than go the used route. Do it yourself and know what you have. Buy used and you never know.
FreightTrain
Banned
2,730
13
Gadsden,Al
Either something is stuck in the rings or broken rings.I vote broken rings.Pistons look fine up top,The Cylinders look great other than that one spot and a couple other single scratchs running up and down but those are just visual scratchs.I couldn't feel them.Nothing looked like it bounced around in there.What is strange is the location of both marks are on the rear of one Cylinder and the front of the other not side to side as you would expect with lateral thrust from the rotation of the engine.
1,160
Unless I was FLAT broke and had nothing left on my emergency credit card, no way would I go through all the hassle of swapping one engine for an unknown unit. You may get lucky and run it for years or you may get a week out of it and it do exactly what your old one was doing.
You guys must have better luck than me, when I try and save a buck, it always bites me in the you-know-where.......
I think FT is on the right track-rebuild the whole thing.......and while it's out, he can repaint the engine compartment and detail it.
1,160
cranetruck said:
The other solution would be to get known good parts from a parts engine. My "parts" engine came with sleaves and pistons missing...
Yeah, but that's my point-until FT's engine started screwing up..............it was and had "good known parts".
Just becuase it is running, you don't know what is worn on the inside.
