Corvette1974
- 1
- 18
- Upper Black Eddy, PA
10-4 on that, I'll definitely keep that in mind. I was literally just watching this: http://www.youtube.com/watch?v=ATydWsWxOf4 and this: http://www.youtube.com/watch?v=27m9jnAurF8If you want the most out of your deuce learn how to split shift.
When you are upshifting you have two extra gears if you can split shift. It is not rocket science and I think there are videos posted on how to do it correctly. Splitting when downshifting is trickier and if you make a mistake you can ruin something quick.
When backing up and doing low speed maneuvering keep it in Low Range. It will not buck and jump around as much and you cannot stall it out even if you put it in 5th gear and let out the clutch.
I have experience with split shifting in the F600, it has a 5 speed and 2 speed rear for a total of ten gears. The 4th and 5th are exactly the same shifting style as a Deuce. Would you suggest always split shifting it or only with a load?
Will
Another point I would like to make is to have someone with you to videotape the run. You just will not believe the grin on your face as you go down the road in it!!
