jdr2710
- 1
- 8
- Colorado Springs, CO
After seeing all the deuce dumpers on here I said to myself "I gotta have one of them!" That and I'll pay for 1/2 the hoist on the delivery savings when I gravel the drive as soon as I finish it!
I found the hoist for a heck of a deal from these guys (no affiliation)
Premium Supply - Home Page
I found it on eBay from a company in Florida, that drop ships from the place in Texas (search on dump hoist) $1200 shipped to my work where they forked it from the truck to my pickup no sweat. There was some confusion as the model number on the hoist was 416 (4" ram 16" throw) but the ram is actually a 5" 16" throw. I called the guys at premium and they confirmed that it is really a 516, with the 416 part number to compete with some other manufacturers. They claim it costs about the same for either size, so they just build the larger and re-label it. The other confusion was that the place in Florida shipped the pump, the place in Texas the hoist, but all the bits got here eventually.
The unload was easy with the jib crane I've got mounted on one of the auto lift posts. Then came the fun of getting the box off the deuce. The door to my lift area is just a few inches too short for the exhaust & the crane I've got mounted to the front of the frame. So I had to roll it backwards on some steel pipe rollers to get it to where the hoist could support it. Once that was off the rest of the work has been easy.
I've got the hinges and hoist mounted, and the tank in place and pumping. It is a 12V pump, but I've got a 50 amp 24-12V battery equalizer so hopefully it will avoid killing the one battery. I've got the 24-12 setup to feed in parallel to one of the batteries, so whatever the pump draws beyond 50amp should come from the battery, then the equalizer should even out the batteries and hopefully all is well. I guess I'll see... Based on the pressure and the cylinder size and where I've placed the pivot point it should be able to lift about 8-9 tons.
I'll be uploading pics to this URL as I work (I'm too lazy/busy to do an actual web page yet, but you can check out the larger version of the pics there):
Index of /images/deuce/projects/dump
I'll update as I remember to take pictures!
