Deuce Fuel Leak
Portland Oregon
I found a small amout of fuel dripping from the tip of this. It appears to be cracked. Does anyone know the offical the name of this piece? Does anyone know where to get parts for this. I believe this is the cold start injector pump not sure.
Keith_J
1,314
Schertz TX
Intake flame heater. That switch on the dash controls it. The poly lines are prone to damage and leaking. Easy to fix with fittings from Home Depot. You need the tube insert fittings, little brass thimbles which go inside the poly line to prevent the ferrule collars from cutting through.
