- 2,102
- 27
- 38
- Delta Junction, Alaska
Immediately under the alternator is a filter canister. It has what I call, "an old time cartridge" that is washable. Its fuel. The fuel line comes from the tank, turns right and goes forward up the right side of the frame, to this filter canister. Is this a primary filter?
From here, the line goes forward, crosses under the radiator & goes into the bottom of the injection pump. then it looks like it comes out of the IP and goes over to the double filters on the top of the left rear of the engine, then back to the IP. Are these two filters the secondary filters? The part I can't follow is there is a tee at these two double filters for a line that goes straight down and back along the left frame rail. It looks like what a supply line would look like. I must loose it, because I think somewhere along the frame, the line I follow, turns into an air line. What am I missing? Regards
