Deuce gearbox bearings
Socast
UK
Hi everyone,
I’m rebuilding the gearbox in my truck (rumbling box when in neutral and whine when moving), I’ve got 4 of the 6 bearings but can’t seem to find any part numbers for the reverse gear bearings (haft at the bottom of the box) it has two long needle rollers with a cage at either end.
If anyone can provide the part number (or somewhere I can buy them), that would be amazing!
I’ve attached a photo of the bearing and an excerpt from one of the TM’s which shows the shaft in question but not the bearings annoyingly.
  • Like
Reactions: HDN
Socast
UK
They must have fit. Google 3110-00-120-4276 one of the prime vendors is federal mogul. it shows j32-1664.For some reason i have j-361644 boxes from my last rebuild.
The J32-1664 bearings are the same as the 708231 bearings mentioned in the TM.
It’s a shame the BCA J-361644 bearings don’t fit as they’re a fraction of the price haha
gringeltaube
Staff Member
2,389
Montevideo/Uruguay
Really ? The sizes are different to 708321, OD for the BCA is 1.620,
OD for 708 is 1.5 ..............
Take another look at that chart: problem is you got that part number wrong: GG is 708231, not 708321
Here are the dimensions and some of the many equivalent interchange part numbers: https://www.steelsoldiers.com/attachments/roller-bearing-h012-0708231-jpg.571739/
Although these bearings are considered obsolete, there are still sources where to get them: https://www.amazon.com/BCA-Bearings-J321664-Bearing/dp/B001GHY5ZM
Socast
UK
That was a typo, and the bearings on Amazon are out of stock. But thank you anyway 😄
  • Like
Reactions: HDN
