deuce generator pulley/ belt squeaking
rhyne6262
Boone, North c
I have this squeak that is coming from the geneartor pulley/ belt on my deuce. The belts are the correct size. I unpluged the generator and the sqauwling was still there. Took the generator off and sanded the mounting brackets to make sure that I good get maximum tightness on the belts. When I spray belt dressing in them the noise stops for 5 seconds. As I continue to mess with the generator the squeak is not as loud. Does anyon have any suggestions?
Regards
Adam
Pinkie
hague, va
Replace the belts and clean the pulleys so no oil is on them? I know when I did that with my air compressor all the noise stopped.
J.R.
