Deuce Groaning Noise on Turns
rneely
Casco, MI
On my Deuce I sometimes hear a groaning noise when I make a normal turn. Is this just a rear axle sliding or is it a sign of trouble?
G-Force
allendale nj
You might have a bad wheel bearing on one of you rear axles. When you turn it puts more of a side load on the bearing and could possibly make more noise than normal. Have you ever had the rears apart???
rosco
30
Delta Junction, Alaska
Make a hard 180 turn on pavement in a parking lot. Stop halfway thtough it, and get out and see if the rear axles are lined up/or not. You said from rear, but other things that cause that are broken engine mounts/trans/T-case mounts.
hndrsonj
Senior Chief/Moderator
363
Cheyenne, WY
You need to check the trunion bearings. If they are loose you will have alot more side to side movement. (Under the round cap between the axles).
73m819
323
gainesville, ga.
Jim you beat me to it, sure will make a bunch of noise if loose, use a bar to check for movement, if there is, tighten.
Gunfreak25
620
Yuma, AZ
Your rear spring pivot bearings are easy to check. Just jack the truck up by the frame under the rear spring pivot point, enough to take all load off the leaf springs. Stick a pry bar in there and see if they have any play. Some guys have reported large amounts of play. Mine is a 54 and thank god both sides are tight as new!! A big nut in there torqued to some 800 ft lbs!
Woodsplinter
Phoenix/AZ
How wierd! I've been noticing the same thing on my A2 but only on right hand turns. Haven't had the rears apart, the cv boots look good with no leaks.
Flyingvan911
158
Kansas City, MO
Mine groans a little on sharp curves on pavement. Off road it doesn't make noise. Everything looks fine. I wonder if it is just stress from the metal giving a little.
