Deuce High RPM major oil leak
fcnavojo
Treadwell/NY
Hi,
I have a Kaiser made multifuel Duece and when it gets to high RPM on the road. It sprays oil ALL OVER the engine compartment. I have washed it several times and tried to find the source, but it only leaks at high RPM/ Load and then by the time I stop and look it is all over the place again. HELP! Please tell me all of the potential areas to look for the source of this leak. It does not appear to be the Oil filter gaskets, but maybe? It sprays all under the hood and is mostly driver side concentrated. Seems to be getting spread by the fan?
Thanks in advance for any help.
Frank
Rmtaunton
31
Smyrna, ga
Good news is your not alone , I remember reading a post about same thing a year or two ago bad news is I can't remember where
gimpyrobb
dumpsterlandingfromorbit!
27,785
747
Cincy Ohio
Nah, start by spraying it down clean and running it in place.
Have someone else run it while you watch.
Start at 1k rpm for 2min, them 1.5k for 2 min, then 2k, etc.
Might even take the fan off for the test, just make sure your temp gauge works.
rustystud
2,388
Woodinville, Washington
Could just be your slobber tube. Do you run a tube down below the chassis ? If not that then check your oil filter gaskets. Remember the bolt is torqued down to 80 ft. lbs.
cattlerepairman
3,111
NORTH (Canada)
I feel with you. Mine has been doing the same thing since I got it in 2009. I am quite certain that it is the head gasket slobbering at the front of the block and the fan blows the oil mist all over the place. Only happens under load and at 2k-plus rpm.
I second testing after a good wash, with the fan removed (so you see the actual leak, as opposed to oil spray everywhere).
fcnavojo
Treadwell/NY
I do not yet have a slobber tube installed. The leak is spraying the underside of the hood. Would the slobber tube do that?
fcnavojo
Treadwell/NY
Thanks for the varied RPM test and the idea to take the fan off. I will try that. Also would the tach cable leak oil where it attaches toward the front of the head? I saw in some other thread someone talked about that.
jbayer
St. Aug., FL/ McGrady, NC
Um, I think it's 60 ft. lbs Rusty.
From TM 9-2320-361-20 section 3-7 f.pg 3-12
1. Coat new gasket (4) with light film of engine oil.2. Install new gasket (4) and body (2) on filter housing (3). Tighten center post (1)60 lb-ft (81 N·m).
152
Birdsboro Pa.
Just this Monday I fixed a simular problem with my m35a2. I had two oil leaks. One was the rear oil filter seal and the other was the tapit cover gasket. I removed the oil filter and seal, cleaned everything and flipped the seal over and reinstalled everything. Next I removed the tapit cover, cleaned it and made a new gasket then reinstalled it. No more leak. Now I only have about 10 more leaks to fix.
fcnavojo
Treadwell/NY
Thanks, I will look at the oil filter gaskets. Forgive my stupidity, what is the Tapit cover gasket?
I have been thinking (dangerous I know). In order for me to try to narrow this down, would it make sense to clean everything and then put masking tape or duct tape or electrical tape on the suspect areas (Head gasket area, Oil filter gasket area, Tapit cover gasket?) to see if they get blown off or just covered over with oil. You guys think that might work?
porkysplace
1,486
mid- michigan
The valve cover on top of the head.
152
Birdsboro Pa.
Looks like I spelled that wrong. It's tappet. It's the cover behind the fuel filters. It's about 6" x 14" long.
I noticed that the mounting screws were all loose. I tightened them and it still leaked. When I renoved the cover I found that the gasket was rough, stiff and brittle.
Flyingvan911
158
Kansas City, MO
Is there any diesel in the oil? When my flame heater nozzle leaked diesel into my motor oil the engine started leaking oil out of the front crankshaft seal. If you have diesel in the oil it might explain why it leaks only at high rpm's.
Jeepsinker
329
Dry Creek, Louisiana
Unscrew the tachometer drive cable, then unscrew the drive assembly from the timing cover on the front of the engine. You will find a couple of rubber O- rings, replace them and reinstall. If the leak continues, the headgaskets is leaking oil out the front and blowing both back onto the oil filters and up on the hood. Not a big deal, mine has been that way a couple years now and I daily drive mine. These leaks look worse than they are because of the way the oil blows around.
Karl kostman
844
Fargo ND
I have a question concerning the term HIGH RPMs, when you say THIS what are you considering HIGH RPMS, 2000, 2500, 3000 rpm what are you saying when you say HIGH RPMs?
KK
