Deuce Hub
comdiver
Buffalo NY
Does anyone have an extra hub for a deuce? It doesn’t even have to be a good one. I want to make some measurement for a project. If anyone has one that they can measure, that would help also. I need the face to face measurement. The bolt circle (not the wheel bolts), the bolt size, the distance from the outside to outside of the bearing races.
houdel
9
36
Chase, MI
Yes, same P/N front and rear, the only difference front to rear is that the front is already "flipped".
comdiver
Buffalo NY
I was able to get the measurements, thanks guys! FYI: 6.62" high, 4" between bearings, 8-1/2"-20 bolts on 5.562" bolt circle. The factory hub # A333E785, rear axle # C240FHX3, bearing #12282182 (modified 3920)
houdel
9
36
Chase, MI
The front and rear hub assemblies are the same - FSN 10896708, Wheel, Hub, Vehicular. The wheel bearings are the same front/rear. The inner bearing (cone) is a #3994, the outer bearing (cone) is a #320, the cup (raceway) is the same inner/outer/front/rear, #3920. The wheel seals are a different animal. There is a listing in the parts cross list for a front wheel seal national 471463 or cr18972, not clear if this inner or outer seal, but I suspect it is the outer seal. There was a recent posting about the inner seals, it is a strange animal because the seal itself is retained in a large outer plate. Most folks have bought the entire plate and seal assembly from MV parts suppliers, but the poster was able to remove the plate assembly and found a replacement seal to replace the seal itself without replacing the entire plate assembly. Search the past 2 or 3 pages of postings for more info.
