deuce ip head needed
stellaruthie
New Richmond Wi
wondering if anyone out there has a good injection pump head ,that they would be intrested in selling?mine is really stiff,and will not return under the power of the spring,its in my 109a3 non turbo ,thank a ton .Jeff
1,169
PM sent
SasquatchSanta
Northern Minnesota
Jeff --- Are you saying that the IP head causes the throttle to not completely release?
My throttle hangs up every now and them. Nothing serious, it just doesn't want to idle down. I attributed the problem to a weak accelerator spring.
An I getting ready to learn something here?
stellaruthie
New Richmond Wi
I bought a 109a3 from GL,and when I picked it up I could not get fuel to the injectors.So I dug into the fuel shutoff,then pulled the ip head off and the plunger is very stiff,and looks slightly scuffed up in the bore.I believe that old fuel and water siting in the plunger cavity most likely caused this condition,thanks Jeff
derby
S.E. MI.
I bought a new one from a member here. it made the truck run like new. with all the work to replace it ,i would go with a new one. i have had mixed results with used parts of that sort. ;-)
