Deuce muffler option
Dore1dog
Salem,Oregon
Family dog who likes to go everywhere in anything that runs when I open the cab door. Neighbors cover there ears as I drive by.
If you are thinking its time to quiet the Deuce and not a fan of the galvanized trash can look, I used a Twister muffler. It's available with a 12" body 3.5" slip x 3.5" pipe. It will fit neatly behind the heat shield. It cuts the harshness out of the exhaust but leaves all the turbo whistle.
Flyingvan911
158
Kansas City, MO
Mufflers on deuces have been covered quite a bit. Search for the words "deuce" and "muffler." There are several that do a good job and several guys have posted decible readings from before and after.
1,178
Looks like Twister has a few options that work well on the M35a2. I wonder which one the OP used(details help)
Performance Exhaust
RAYZER
59
sanford/florida
The dynomax is a slight interference fit over the stock pipe and you can weld or use a special steped clamp that you can get from napa.
bigelk50
13
albany, Or
I have heard the truck in the first post. It is alot quieter! still sounds great though and you really have to look behind the heat shield to see the muffler.
wildbilly1760
Pottersdale, PA
What was the price of the twister? the Dynomax from Summit or jegs seems to run about $50. That seems like the price range I would like to stay in. Yes the Twister looks good, and fits in behind the heat shield like I would want. The website listed didnt list a price, and I havent recieved any emails from them. The website does make it look like a good choice.
Jimma
Hartwell, GA
I dont like how most of them are above the heat shield but with it inside the truck does not look modified and goofy. I would like to know how much of difference in db's it makes. The other side of me says part of the fun is the noise.
Heavysteven
10
Hickory Flat Ga
I think mines a dynamax as well. I did not even try to hid mine. Just had it welded to the upper exhaust. With out a doubt it helps out with the sound. A walker would be nice but they look bulky.
MO MV man
Imperial, MO
I couldn't be more pleased with my Donaldson.
It's an industrial muffler (built like a vault) and no matting/packing to blow out or get sooted up over time.
I lost around 11 dB at idle.
And the exhaust note is awesome. VERY deep.
The whistle is still there. :beer:
RAYZER
59
sanford/florida
The dynomax fits behind the shield ,can't tell its there unless you look close,(see my album) , the d b level diff is about 3, don't worry, there's still plenty of noise!
