Deuce oil level question
russojap
Knoxville TN
Before I changed the oil the level on the dipstick was about 1/2" over the full line. After draining the oil and replacing the filters I added 5 gallons of oil and the level showed to be low by around 2 quarts I think. However, I wanted to run the engine first to not risk overfilling it.
Now the level reads back where it was before I changed the oil. How could the oil level have increased? It seems more likely it should have actually DECREASED after being circulated through the engine and new filters. Or am I waiting too long after running the engine to check the oil level? I thought the engine is supposed to take 5.5 gallons, how can it be over filled with only 5 gallons? Thanks in advance.
Edit: Never mind, thanks to Kevin I now understand that I didn't allow enough time for the new oil to flow into the oil pan, so the initial reading was inaccurate.
dmetalmiki
986
London England
When the vehicle 'stands' for any length of time the (Ridiculously! Designed) filters( Ensuring NO oil for quite a while on start up) drain out raising the oil level in the sump.
Thus, When checking the oil level, Run the engine for a minute and check the oil level again, whereat it should (Will) be at the correct level.
As an aside, Is why I fit a pre prime oil pump to all my M series trucks.
I then have full oil pressure at start up.
crzyxj
Lander, WY
So I ordered a spin on filter kit here off the board. I would assume that I will have oil pressure faster because modern oil filters retain the oil. Would that be correct?
topo
farmington NM
When my M52a2 had a Multi fuel adding the spin on filters where great no more guessing on how much oil was still in the filters .
The filters stayed full and the dip stick checked the oil level in the pan.
rustystud
166
Woodinville, Washington
Yes. The new style filters usually have a "check valve" in them preventing drain-back. I have "full" oil pressure in under 2 seconds now. That's setting for a week.
dmetalmiki
986
London England
Yes, Not as good (or as high a starting pressure as with a pump), But Much better than 'the (Scary) no oil pressure for a 'week'" saga.
rustystud
166
I thought about adding a pre-start "pressurized oil system" but the cost was pretty high. So by adding the spin-on oil filters I got a pretty good system going now. It's not perfect, but it serves for now.
