- 3,923
- 77
- 48
- Comfort, Texas
I am picking up my M35A2 tomorrow for the 60 mile drive home. I have test driven the truck twice but still want to go over all the fluids prior to setting off. And yes, I have searched and read past threads and the TM's and LO's until I am half blind and very frustrated. So....here goes:
1. I want to check and top off the tranny and transfer case of necessary. I know about the bent knuckle approach but I am not sure where the fluid check and add ports are on these items. I could not find a diagram, picture or narrative in the TM's other that servicing breather caps. Can anyone help?
2. I have read a hosts of threads on GL-1 and alternatives but most posts go back a year or more. I cannot find GL-1 locally (yes I checked my truck center and NAPA's) and I certainly don't want to open a whole new synthetic debate. I was planning on adding Amsoil 80/90, Castrol 75/90 or Mystik 90W gear oil if I need to add any. Has there been any concensus as to a GL-1 alternative of late?
3. What is the lug nut size for the standard wheels and for the spare winch? Will a 1/2" drive breaker bar be sufficient?
4. Will a standard 1/4" air fitting work with the Gladhands at the rear of the vehicle. My tanks are holding at 100psi. Should the vehicle be running when performing this service?
Looking forward to responses.
