deuce power steering gear boxes
ODdave
lansing michigan
As of right now i am just asking a question but want honest feedback. I have been comming across Ross HF54 gearboxes lately and wanted to know if there would be any interest from fellow members in them. These if you are not familiar with them, they are the Hydro Assist (power steering) box needed to convert your deuce, search Ross hf54 on this site. All are used but good condition. These things are a real PITA to get off of the trucks but if there is interest i dont mind. I would have to get $150-200 but that is far cheaper than air-O-matic. They would include the spacers and the pitman arm.
Do note that these are not a direct bolt on and will require some fab work, but im shure there is a few of us out there that are capable of this.
I have added some pictures for an idea of the condition of the parts, Also these boxes have bosses that can be machined for ports to go to an assist ram on the axle (one box in the pictures has this done) I have included a pic of and assist ram also. I may find more of these rams, if i do is there intrest in them as well?
harleyrkc
Burton, MI
I may be interested. What are they off of? And outside of the obvious brackets that need fabricating, what other parts are needed to complete an installation?
ODdave
lansing michigan
They are from older model med duty trucks. You would have to fab a 2 joint steering shaft, I am going to try to sorce the parts for the shaft also. I have some but not enough to start selling them.
ODdave
lansing michigan
I dont beilive you will find any that will be a "no fab bolt on" inside or out. These are the exact box that was used in the link i posted. Inside frame rail.
Kohburn
SOMD
based onthe link the assist ram is not necessary.
so basicly a kit with the pump, box, hoses, arm, and joints for the column.
m-35tom
221
eldersburg maryland
and you need a new upper column to attach to. gamma goat is as close as you will find and they are new and cheap. tnj murray has had them. saginaw 710 bolts on the outside of frame.
tom
ODdave
lansing michigan
  1. and you need a new upper column to attach to. gamma goat is as close as you will find and they are new and cheap. tnj murray has had them. saginaw 710 bolts on the outside of frame.
    [*]tom
You can modify the original steering column to work. Are you Shure the 710 will fit the original 4 bolt holes?
m-35tom
221
eldersburg maryland
you can make a whole new column too if you want to, but the goat column already has the lower bearing and all the horn parts. and may only be something like $10. and is NEW. you want to make all that stuff? of course the 710 does not line up with existing holes.
tom
ODdave
lansing michigan
Wow, sweet info on the goat column! I will look into that. I was just wondering where the 710 came into the thread, not tryin to be cynical .
westexhunt
San Angelo/Texas
I am confused as to why we are now talking about wheels but I would like to have power steering on my deuce, what parts do I need and how much would it cost? I can fab stuff but only have so much time so more details would be appreciated.
gringeltaube
Staff Member
2,476
Montevideo/Uruguay
....... These are the exact box that was used in the link i posted. Inside frame rail.
According to your pics posted, that is not exactly correct... read some more about differences between models here: http://www.steelsoldiers.com/deuce-modification-hot-rodding/15916-power-steering-deuce-3.html
I would not recommend using the HF54044 model. Besides other differences the mounting surface is NOT perpedicular to the pitman shaft.
Also, take a look at my scaled drawing, below.
G.
