jesusgatos
- 28
- 38
- on the road - in CA right now
The 800-series 5-ton steering columns are similar to the deuce columns, but they're shorter and use an intermediate shaft that is connected to the steering box. They use a second column mount (identical to the one on the dash) on the firewall. Got one for Mah Deuce that I'm planning to connect to an orbital valve. Might end up just mounting that directly to the firewall though. In any case, those 5-ton steering columns might also work for you guys...
