Electric is my last resort. I have the hoist mounted and all i need is a way to power it. Do those electric pumps have the capability to run a two way valve?
Two way as in up and down? or two different utilities - winch and dump?
I would say that it would be dedicated to just the dump and winching is best done with the pto so you can still use the low range transmission to pull your self out.
My one ton electric hydraulic powers the dump up and down and a separate hydro system for the plow gear.....
Sounds like you need to find a pto... electric would be a last resort.
To find a fan belt clutch hydraulic pump off an old tow truck would be a score and you could port as many valves as you want.... most of those run up to 30 gallons/min at 3000psi... finding a place to bracket it to in the 6by might be tricky though.... still a bit more expensive than a quality take off though...
High Pressure Hydraulic Clutch Pump — 2.32Cu In.
Each pump operates off truck or equipment engines. Mounted in line with engine belt 2 groove pulley. 7in. pulley diameter. Takes two type A 1/2in. belts. Clockwise rotation. Foot mounts with two 1/2in. tapped holes. Maximum pressure 3000. 1 1/4in. NPTF inlet, 1in. NPTF outlet.
Overall Rating
5 / 5
Rating Summary (1 review)
5 stars
4 stars
3 stars
2 stars
1 star
1 of 1 would recommend this product to a friend. See all reviews below
Write a review
Item# 1082
Only $489.99
Guaranteed Lowest Price
Qty
In Stock
Ship Wt. 35.0 lbs
![](http://www.northerntool.com/images/buttons/calculateshipping3.gif)
