Deuce Re-Inspection Question
Tinwoodsman
76
Comfort, Texas
I rechecking a deuce tomorrow that I am hoping to purchase. When I first test drove it, the air pressure buzzer did not come on when I turned on the switch. I will look at the pressure gauge but want to know if there is another way to check to see if the system is pressurizing?
coyotegray
10
Oklahoma City
Drain the air tanks. It will show the system is pressurized and should drop the pressure so you can see if the buzzer/gauge work.. The buzzer won't come on every time you flip the switch, only if the pressure is below 60lb.
This is somewhat academic. If you drove it and you were able to stop, it was pressurized.. :neutral:
Andy..
Tinwoodsman
76
Comfort, Texas
Cleared the air tanks and the buzzer went off as soon as I turned on the switch. Held a steady 95 to 100 psi during my test drive. :driver:
