- 12,195
- 329
- 0
- gainesville, ga.
DID thay LOOK at the RUBBER hoses, look inside for DETERIATION, because from your first post, that is WHAT you DESCRIBED, when you rocked back and forth and at the same time stomped on the brakes, you FORCED the blockage to give, With bad RUBBER hoses, IT WILL DO AGAIN WHAT IT DID AS DESCRIBED in the first post , only maybe this time one of KNUCKLE hoses will block causing a front brake lockup with the corresponding pull to one side, this would not be good in dry weather, let alone wet, snow, iceWell myself and a couple of heavy line techs looked the brake system over and couldn't find any real issues with the brake system. When I purchased the truck it had been gone through by a very knowledgeable person on these trucks. He works on them plus sells them. I know that no one else should be trusted in the issue of the safety of the vehicle that I am driving and that's why today when I had some time to actually check things out, I did! Thank you guys for all of your input! This site has been great so far!
COMMON sense would be not to drive the truck TILL you found out WHAT CAUSED the EVENT, just because ALL looks good DOES NOT answer the cause, till that CAUSE is found and fixed, the EVENT can and most likely will happen AGAIN
SORTA like this.
Just because my X looked good, does not answer the 1000 reasons that CAUSE her to be a X
