RAYZER
- 59
- 48
- sanford/florida
Well,i needed a tractor to pull my m146 trailor, i wanted to stick with a 2.5 ton for a few reasons: the m146 was designed to be pulled by a deuce, multi fuel capability and i allready had the deuce ww and couldn't find a m275a2 within reach.
So i bought all the components off the back of a junk 5 ton cheap and went to town, i put the 5th wheel just foward of center of tandem,removed 1 cross member,cut 12" off the back of the frame,installed the original pintle cross member back in,took 8" out of the spare tire rack ,used grade 8 bolts to put everything together.
A few things i still need to do: find some m818 tail light mounts, plumb in the air lines and trolly brake (still trying to figure that out).
pics coming!
pics coming!
