Deuce shakes at 40 mph+?
supeman100
Austin Texas
Hey guys, I just bought a bobbed deuce. It has 46s and is in pretty decent shape. But when i hit around 40 or more miles per hour the whole front end of the truck starts to shake, almost like its bouncing. What do you think is causing this? I filled all the tires up to the correct PSI and didn't change anything.
Thanks!
MWMULES
352
DESOTO, KANSAS
I would have whoever you bought it from fix it! That is unless you added the wheels and tires.
eme411
pefferlaw ontario
also check that your knuckles are as tight as they should be and check , tie rod ends, etc, and media blast your brake drums ,40-60 years of paint can give you one crazy of a wobble, you may also need to get the drums balanced, did all this on my deuce , drives like it's on glass,
