Deuce Starter Question
AZDeuce
Tonopah, AZ
Doghead
I haven't forgotten about post # 7, I just haven't had a soldier B around to crank the engine while I poke around with the multi-meter.
Is there a source for NOS, relays and solenoids? (just in case!)
1,188
I also do alot alone, I have a set of meter cables that have spring clamps on them(like a battery charger uses).
The relay I have purchased from Saturn Surplus. The starter solenoid, I get from my local starter/alternator shop.
AZDeuce
Tonopah, AZ
A question regarding the solenoid, I was able to unscrew it off of the casting that's bolted to the starter. I tried to screw it in the same amount as it originaly was when I reasembled it. But I'm wondering with the sanding of the disc and contacts, if maybe I shouldn't have screwed it in as far......or possibly I should have gone farther.......any ideas?
1,188
The correct way to adjust it is, to remove the starter and measure the throw of the Bendix.
It is supposed to stop just short of bottoming the drive gear on the housing snout. The spec is .020"-.050" gap at the thrust washer.
