Deuce starter
1,168
TM 9-2920-243-34 and TM9-2920-248-35 are the tech manuals for the starters(Leece-Neville and Prestolite, respectively)
The part numbers are in the TM.
Take time to look at and read and download all the TMs that may be useful to you(depending on what equipment you own).
hoop
14
va
doghead...can you add them to the Deuce FAQ section. The TM section is a beast to get thru.
1,168
YOU can add them to the WIKI. That's whats good and bad about WIKIs! If we sticky or FAQ everything, the list will be long!
Simply put, if you own the equipment, arm yourself with all the TMs and info you need(on your own Computer).
Someday, the site may see improvements in areas like TM's, Chat, advertising etc... All we need is an administrator that can and will make the improvements! (I been asking for years):sad:
hoop
14
va
Well, maybe someone here who knows how to post it with the same format that is there, will post it.
