- 4,640
- 32
- 38
- Cambridge, Ohio
G-Force,
Yeah, the vent is free and clear. I also made extra sure of that while I had the tranny out of the truck. I don't know what oil the military unit at Ft. McCoy used in it but it was definitely gear lube (gear lube has it's own distinct smell to it). Was it the proper gear lube???? That's the $64,000 question.
I don't have a problem running it at the level it's at now. As gringeltaube pointed out, there is quite a bit of space above the fill hole to the top of the tranny, so that tells me that the lube to the upper end is a splash lube method and not submersion. Even being a little below the fill hole, it should still be getting plenty of lube up top. After 4 hours of hard running to Columbus and back, the tranny was not overly warm, I checked it out as soon as I got home since that was the first hard trip I subjected it too after I changed the clutch disk.
I will, however, do as you suggested and check it cold and then as soon as I finish a hard run to compare the levels. It is quite possible that the lube the military had in it wasn't the proper lube. I know I used NAPA 85w/90 in it when I filled it back up.
Thanks for the input.
