- 34,012
- 1,808
- 113
- GA Mountains
1) The military tranny hoist doesn't work that good. Actually not at all.
2) Just because you can jamb from 4th to 5th without a grind doesn't mean you should.
3) Short come-a-longs are much better if you use the "Across the cab" method.
4)Setting up the PTO on the ground works really good, installing the tranny with the PTO in place works really bad.
5) Gasser PTO shafts are more of a headache to install than trannys with PTOs attached.
6) 5 year olds can't differentiate between 1/4' and 3/8" drive sockets.
7) Top shelf creepers and driveways on a tilt can be frustrating.
8 ) The deuce is just high enough to be out of reach on a creeper but just low enough to prevent sitting up.
9) It's nice to have all 5 gears again.
