kcollum
- 0
- 6
- Long Island New York
Hello, I am new to the madness, I have purchased a 1970 Jeep Corp. Deuce. in good shape. It has a vibration in the floor board at 25 mph and above. Checked all fluid levels and all are good and clean. I remove the front drive shaft and took a ride, no more vibration. Front drive shaft had small amount of play in u-joints so i have replaced them. Re installed and vibration is back but not as bad. The front output
yoke on transfer case has a little play not bad and no seal leak could it be I have a bad pinion bearing on the front wheel drive output of the case?
Thanks for any input.
