Deuce trip n/e KS to FL Orlando.
AmericanWeapons
Orlando, FL
Hey guys, we finally stopped for the night. We are near Chattanooga, tn and have about 600 miles left of our long slow journey. I am happy to say that the deuce is chugging along and no further issues up to this point. Thanks for everything guys and I'll let you know when we get back on the road in the am.
swbradley1
Modertator
1,918
Dayton, OH
Good luck and unless you want to add a lot of miles to your trip just go straight through Atlanta. The traffic in that place sucks no matter what.
Going south on I75 when you make the turn at 75&85 make sure you get from the right lanes to the left a couple of lanes as soon as you can because next thing you know you will be stuck in the right going west and not on 75.
Other than that I have only driven one time through there where I didn't really like it, last year going to the rally with Gimpy in front at dark after my medical incident. ;-)
It's just traffic.
MWMULES
350
DESOTO, KANSAS
Don't forget to post some picture documentation of this journey and glad things are now going your way.
FloridaAKM
395
Gainesville, Florida
I drove a Deuce recovery thru Atlanta this past summer & it was worst thing with the traffic jams, people cutting in front of me & running the clutch & brakes trying not to hit people who thought of the Deuce as just another truck. The worst part was being routed on the East bypass @ around 5:00 pm, due to being cutoff from the West bypass because of idiot Atlanta drivers. I will NEVER do that again; once back on I-75 South, it was smooth sailing back to Florida.
Glad your trip has been a safe one so far with just a fuel leak that you got fixed. Ooops, see that you had wheel cylinder issues too. Good luck getting those fixed also!
It's just traffic.
1,191
Maybe the Deuce Doctor can make a house call?
1,156
I'll be happy to help and I've convinced the local Napa to stock 4 of the correct M44 wheel cylinders for me, so I can get them.
AmericanWeapons
Orlando, FL
We are currently in cartersville, ga. res. was a little low nothing crazy. My question is how dangerous would it be to try to limp this to florida with a leaking wheel cylinder. It's leaking from the fitting but the fitting is tight
porkysplace
1,494
mid- michigan
From the copper washers or the line ? leaking brakes are the same as no brakes .
FloridaAKM
395
If you limped in, checking the master cylinder often; you might make it. If the wheel cylinder takes a dump on an emergency stop for anything along the way...it could be a really bad day for you or who you might run into. Porkysplace is right, leaking brakes are the same as no brakes. Lady Luck & the courts sort this type of stuff out; you get to make the call.
I know a guy who would push the envelope to the extreme, against all odds & make it home early. I call him Teflon, because nothing sticks to him & he sides thru home base most every time.
Good luck on whatever you do to get home safely & in 1 piece!
1,191
It is more likely the line is actually bad, if leaking from a tight fitting.
Remember, with a single circuit brake system you loose all brakes with a line failure.
MWMULES
350
DESOTO, KANSAS
I just sent Clinto Sean's number as 2 heads are better than one, at least that's what my Pop always told me! Looks like it is just a weep, enough to goo the wheel but wasn't that low on fluid.
Andrmorr
Burlington, NC
This thread is highly educational for me since I just won a 5 ton in Atlanta and will be running Americanweapon's route backwards headed up to NC. I'm new to SS but really appreciate all the info I've been able to gather in prep for the recovery.
73m819
328
gainesville, ga.
What 5t did you get, the nice new dump maybe.
FloridaAKM
395
Well, then you are about ten miles from me right now on the other side of Gainesville. Weather is cloudy & 47 degrees, but hasn't started raining yet. Good luck with the recovery thru my/our area & on to Orlando where is should be warmer & dryer. Glad you got the leak slowed down to a slight ooze. Maybe you are made of the teflon material too. Take care & be safe for the remainder of your trip! Post of any problems that might arise as you pass so that we can help if needed!
Andrmorr
Burlington, NC
Sir yes sir, got the M930A2. Talking to the yard now to schedule the load out. It should be an adventure but I'm hoping M_rphy doesnt call Shotgun on this ride. Am a little concerned about the dirt line on the front tires where you can see it had been flat...not happy with that on the front. Will the rear tire/rim fit on the front of an A2?
Really like your signature block...I'm new to SS but not new to trucks or forums so your sig block speaks volumes.
I see you help with recoveries in ATL so I'll keep your phone # handy if I need some local expertise.
