Deuce wheel bearings...or lack of!
randyscycle
Rhoadesville VA (where!)
Finally got around to pulling the deuce brakes down to do all the wheel cylinders, fluid, hoses and front boots, when on both front wheels I found this. Surprisingly it didn't stop too bad. Not great, but not too bad considering the shoes hadn't touched the front drums in a loooooong time. :shock:
Glad I didn't just title it and head out on the road as is.
All new seals and bearings on the way, so we can go as well as stop.
m16ty
227
Dickson,TN
I've never seen a wheel bearing in that bad of shape that hasn't come apart. Did the wheel spin freely before you broke it down?
OPCOM
29
Dallas, Texas
Makes me wonder if they ran out of grease and improvised using cheese like we used to when the stagecoach bearings would overheat and sieze up.
Barrman
2,172
Giddings, Texas
Glad you found that at home instead of on the road Randy. Put one piece boots on and you won't mess with anything in there for a while.
maddawg308
814
Appomattox, VA
That is scary looking. Makes me nervous and wanting to tear down my wheels as well and take a look. Be glad you caught it when you did!
randyscycle
I never really drove the truck more than a mile or two up the road, simply because I expected to find a few things that needed attention before I struck out on any kind of drive. Most everything has been on the property at slow speeds. With the whistler, I probably wouldn't have heard it until it fell off :lol:
The wheel did spin fairly free, when I jacked it up, but had some lateral play. No surprise there looking at it..
Its getting ALL new bearings, seals: inner and outer on the rear, and a complete teardown to install new one-piece boots. The boot on that wheel wasn't torn, but its really soft and mushy feeling, and I suspect since there was no gasket on the axle flange, and the inner bearing seal was really stiff and old, that the water found its way in there too.
The spindle seems to just be surface rust and not pitting or anything I'd be worried about. It actually cleaned up really well in there with just a good shot of Super Clean and a hose.
So as soon as the UPS driver shows up with my seals and boots, I can start going back together.
